DangerousPirate
So I recently came here because my engine stuttered a little, thinking "Oh okay, must be some air in the system because the last few times I used it, it worked perfectly well".
The biggest issue seemed how to operate the system as there was no obvious bleeding screw to me.
Now the problem seems to be far worse than previously believed.... Having found a replacement for the screw on the bleeding system I went back to bleeding air, but less and less diesel arrived at the pump, until it was dries up. Weird. I just filled up 2-3 liters yesterday and didn't run the engine since, so might now be much but at least some.
And I notice the diesel in the primary filter has a funny colour compared to the fresh red diesel. So I tried to shut off the valve and change the filter, but the valve is corroded and won't turn!
Okay, that's really bad.
But okay. i burn that bridge when I cross it. For now, the diesel. I did a tricky drain by partially unplugging the bottom of the filter and catch it in a plastic cup. Bit of water in it, and it's more brownish than red.
The filter was drained and despite the open valve nothing came to the filter after it. Hm. Must be because they're almost level, couldn't tell you from the top of my head if the tank is above the filter or the other way around. No big difference.
Okay.... So I decide to change the filter, seizing the moment and all, but I didn't have this filter in particular on the boat. Got everything else. Hm.
So at least I clean the bowl, which was sort of slimey, didn't think anything of it then, and put it all back together.
Having put all my diesel in the tank I didn't have any to fill up the glass bowl/filter so I tried the lever but nothing happened at all. Hm.
Changed the engine filter in the back, hand tightened it and really hurt my knuckles doing so... The other filter had black gunk in it.
Just googling around about the corroded valve I found out symptoms of diesel bug (and the sheer existance!).
This almost fits it to a tee!!! What now? What are sensible next steps?
Can the diesel bug damage the engine? How can I be certain it is that in the first place? Is this going to be very expensive, if it is that?
What else can it be? Gunked up diesel hoses? I admit I don't know how old they are exactly, but the engine seemed well kept from the previous owner and the hoses don't look decades old either, they're still springy.
One thing: the boat has not been moved from beginning of april until end of last month. In april the engine took a little to start (suspecting the cold, but not so sure now..).
And in the last weeks I ran the engine for power on the boat in idle for a few hours a day.
The stuttering started last week or so.
The engine is a beta 14.
