P
Peegee
Finally (I hope) got to the bottom of bad starting and rough running of my VP2002, culminating in today, draining tank, removing inspection hatch, and discovering all manner of goo in the bottom.Also found the fine gauze in lift pump was clogged with said goo. I'v cleaned tank till it sparkles...well,you know what I mean, and my intention now is to put in fresh fuel, bleed through to seperator till happy its flushed out any lingering bug, then flush through rest of system till clean (scrapping the flushed fuel). Question is, would you put a dose of cleaner in the main filter before screwing it on so as to give the injectors a clean. I had them tipped and serviced a fortnight ago and the engine ran like a dream but I think they have become gummed up after running for a few hours.Any suggestion very gratefully accepted. p.s. reckon I will scrap the removed diesel (50ltrs) or is there a safe method of filtering/re-using
