Jamie Dundee
Recently discovered I had a dose of the bug despite using Marine 16 each fill up, prefilter bowl full of crap. I’m guessing this is a historical problem as this is my first year with the boat.
Gave the tank a double shock dose of M16 and changed prefilter and engine filter which seems to be doing the trick as far as the bug is concerned. What I’m now finding in the prefilter sight glass is a clear liquid, diesel in appearance but viscous, a bit like thin engine oil. I’ve never seen any evidence of water in the prefilter or when I pumped the bottom of the tank and wondered if the water could be emulsifying with the diesel. I know M16 is a biocide but found the following in the PBO group test of bug treatments.
This clearly mentions water being ‘dispersed’. Could the substance in the prefilter be a diesel/water emulsion. I’m draining it regularly, the engine is running well, although prior to redraining the prefilter does seem to lose a bit of power, burning a diesel water emulsion is known to produce less power than pure diesel. Generally puzzled
