Cardo
So...
I posted a little while back about having air entering our fuel system somewhere around the CAV filter. We eventually diagnosed it was the Eberspacher fuel take that came from the second fuel outlet on the CAV filter. As a temporary measure, I removed the Eber fuel pipe and taped up the outlet. After managing to bleed the filter, things worked fine.
Fast forward a month or so and we have now properly blocked off the second outlet and had a lift pump inserted prior to the CAV filter in order to assist with bleeding the fuel system (as the engine's fuel pump just wasn't cutting the mustard).
But now we have developed a nasty air leak into the CAV filter. I have narrowed this down to a leak up to the filter inlet as the bubbles appear out of the bottom of the filter element, so the air is entering on the inlet side of the filter body. Having played around with the new lift pump, I find that if I pump with the bleed screws closed diesel will drip (not gush) from the joint where the copper fuel pipe enters the CAV filter. I'm guessing/hoping this is also the source of the air leaks when the engine is running.
I have removed the pipe from the filter body to see how this seals. I enclose a photo of the pipe... (Apologies for slight out of focus, camera was playing silly beggers)
The copper pipe ends in a "nib" that wedges into the inlet on the filter body. The "nut" screws into the thread on the filter body and pushes the nib into the inlet. I presume this is meant to create a seal. However, the nib and copper pipe itself don't seem to be one, there is play between them. Is this normal? Or have things gone awry? Or should the compression of the nib as the nut pushes it in create the seal? In which case, any thoughts on how to improve the seal? I have checked the condition of the copper pipe and it seems to be ok, I can't see any obvious cracks.
Thoughts??
Thoughts??
