Divemaster1
Thought about this one and you could have an issue with your stop solenoid .. as referred to by others ... a simpler thing with respect to stopping the engine, (as compared to replacing or cleaning up the solenoid) is the cable adjustment (yellow arrow in pic ... believe this is your SB engine). this needs to manage to pull the leaver to full "no fuel"... if it has worked loose by vibration, you will not pull this to full "no fuel" .... and if you have an ignition barrel issue (as this provide your stop), you may pull the stop solenoid to partially shut during the starting process, which will maker her un-likely or slow starting ... once governor kicks in at starting moment, solenoid may restrict WOT somewhat............., I had trouble shutting that engine down, which is an intermitent fault, ...........
