Depth transducer wiring problem
madabouttheboat
20 Jan 2005
UK, but for Covid it's England
This is the cable end of a transducer currently installed on the transom of the boat. The old head unit is long gone but it was a Navman Fishfinder. The transducer outputs speed, depth and sea temperature. There are 5 coloured wires, brown, green, red, yellow, white; 1 bare wire and one considerably thicker black wire. The depth part of the transducer works on 200mHz.
On the other hand I have a simple Navman depth display that requires a 200mHz transducer. The plug on this is an RCA type.
I am thinking that if I choose the right wires from the selection above, I should be able to put the other half of an RCA connection onto them and have a useable depth readout. One of the wires will be the negative/ground and will go to the plugs case. This will either be the bare wire or the thicker black one I am certain. I may even need to join these two together. The other wire, that needs to go to the centre pin of the RCA connector, will be the depth positive/signal wire.
The question is: What one is it? How can I work out the correct wire? Will I damage anything using the wrong wire in a trial and error mission?
I think the transducer is Airmar, but all of the wiring diagrams I can find online suggest that Airmar use a blue wire for the depth signal in a speed/depth/temperature transducer, and I don’t have a blue wire. This is a typical wiring diagram from Airmar for a Navman speed/depth/temp transducer.
Can anyone offer any assistance or advice?
