catmandoo
My ST40 depth instrument failed as the cable close to the transmitter was damaged due to vibration against the through hull transducer plastic casing edge
Raymarine said replace but admitted i could try to rejoin cable and re-insulate using heat shrink but was not successful due to restricted space and closeness to transducer .
I don't want to lift out next year just to replace a through hull transducer so am looking for an alternative to put in with out penetrating hull . I have thought of a transom mount but understand this could be affected by turbulence .
Also fish finder but where to mount ?
Any one gone down this route before ?
what did you do and was it successful ?
