Dill et Bound
I have to rely on accurate depth readings due to a large tidal range, and a large area between France and Jersey and the Bay of St Malo where you can often get off and walk, a mile or two..
My Sealine 255 was originally fitted with a Stowe depth sounder, later replaced by a small Raymarine unit using the same transducer. I needed to replace an ageing GPS. Garmin 126 so
put an additional GPS Chartplotter in the form of a Garmin 551 S attached to a stern mounted Garmin transducer onboard 2 years ago..
I find no problem with either unit at speed.. They read to about 1/2 metre of each other in depths up to about 8 meters up to 22 kts.
I never rely on the split screen visuals on the 551, but tend to use the Raymarine for Harbour and anchorage work.. I have a shallow water alarm set for 2.5 meters..
In depths over 8 meters they do vary slightly more, but still give an acceptable idea of depth at higher speeds, although I have never tested with a lead and line..
I also kept the old Garmin Gps attached to my Radio on a separate circuit to the new 551,giving me DSC.
Therefore ensuring that should I blow a fuse, I have Gps available on the other circuit, and usefully depth..
