Degreasing/Solvent for use on cast iron
  • Thread starter Thread starter JEG
  • Start date Start date
JEG
13 Jul 2001
Surrey
Can anyone recommend a widely [hopefully] available brand? Gunk from Halfords does not seem appropriate - rinse off with water being advised.
I thank you.
John G
also know a guy that put his cylinder head in the dishwasher worked a treat .if you do, get up at 3am and do it or you will have your c**k chopped off!
FWIW I've used bog standard acetone a few times and had no problem with the subsequent adherence properties of the paint systems applied.
Traditionally it would have been done in a degreasing tank with trichloroethylene or trichloroethane. I dont know what they use now that these chlorinated solvents are no longer acceptable or even available. I see the point about rinsing with water so that rules the dishwaher out as well.
Use paraffin to get it clean then finish off with white spirit as suggested by nedmin or with the thinners for the paint you are presumably going to apply.
If its not too big, take it to the local electroplaters, and have it sonically degreased, that works best.
Whats it for?
Acetone is the job
Agree with acetone.
Had to remove oil from weathered galvanising before using epoxy. First tried washing up liquid - useless. Then tried concentrated International Super Cleaner - better but still greasy film. Wiped twice with acetone on paper towel - completely oil free - water did not bead on it.
use a strong solution of the cheapest washing up liquid (ASDA 19p/bottle) /forums/images/graemlins/grin.gif, scrub in and wash off with water (Fresh)
G'day John,
I have used Acetone with no problems, keep up-wind, buy a lot more than you need, it's cheaper in bulk and keeps forever, very handy cleaning and degreasing fluid. Don't throw out used Acetone, put it in a container and let the crap separate out, drain off the clear portion and use it again.
Avagoodweekend......
Acetone is the job - but Chloroform is better
.. as used in many professional applications but, although not restricted, it is difficult to get retail in any litigation driven state. Being less volatile it stays on the job longer. It is also less deleterious to painted surfaces. There is no personal danger unless you breathe it in vapour form excluding other air for quite a time.
Steve Cronin
Re: Acetone is the job - but Chloroform is better
Gentlemen,
Thank you all for time & assistance. The item is a turbo housing, with fans in place, and it's a v...o; therefore expensive to replace. Trichlorethylene used to be great but they found that if you put a rat in steel shoe box & forced it to breathe the fumes for four hours a day the rat suffered! How did our ancestors live long enough to reproduce?
I intend to try paraffin followed by white spirit.
Thanks,
John G
