mogmog2
I need to repair some reinforcement in one of the keel bilges: one of the retro-fitted gussets has partially come away. Presumably because of inadequate preparation...
The bilges are now very oily, following a major engine oil leak.
My uncle came and had a look for me. He is a retired aeronautical engineer specialising in composites, so advised me about the materials and stresses etc. He also stressed the necessity of getting the area clean, but they use Trichloroethylene as (the best) degreaser. However, this is problematic to the average bloke.
After removing the failed tabbing, I intend to remove the original surface. However, he advised that some grease contamination will occur, especially with a grinder, as material is moved around, so meticulous degreasing is necessary, ideally as a wash rather than wiping.
The West guide is a bit lacking in detail and that is the most comprehensive guide I've found.
Has anyone successfully done something with similar conditions (this is obviously different from say repairing a deck or general non-greasy area for which a wipe with acetone would suffice).
Any tips? Thanks.
Any tips? Thanks.
