McSalty
....measure first......
Uh,... ignorant me, but: What can I measure (or how to detect short circuits?) since the batteries have been bone dryy for some 3 or 4 years at least?
So, I have 12 x 6V 190Ah deep cycle Trojan TE35 Batteries which most likely are "dead". In view of the unxepected expense (see above) I need to find a way to revive them, or else a new set of domestic Batteries alone will be some € 10,000 uhh umm.
If you see a lowish resistance chuck them.
If resistance is high .......
Ye gods what have you bought a submarine? Suggest you do a search on here on batteries and the advice to calculate your amp hours needs and then match this to the size of the battery bank you need. You may find you don't need to carry all that lot and save a few bob too.
Humm, I guess you unfortunately will be probably right - but with that price tag it's worth a try? No?
Could you comment, like in "numbers" what a "lowish resistance" and what a "high" one would be like?
I am having an ohm-meter right in front of me which I'll take down to the boat tomorrow. The water I added some 48 hours ago, so something surely must have "happened" in the meantime?
Hi Willow,
just came back from the boat and had my meter/tester with me today.
Auto of the 12 batteries 11 did read an ohm value of pretty much all of them "100" - and a Voltage between 2 and 3 V (6V Batteries)
1 out of the batch was completely "dead" - no Voltage at all, no Ohm-reading at all. (tried it numerous times, needle of the meter did not move)
What is your conclusion from this information?
Is there any hope for the patient?
I fear you'll find Trojan have abandoned the "domestic leisure market" (about 2 years ago according to my reports).Sometimes when people are asking for advice, in reality they only want to hear what they would want to hear....
I, in this case was no exception - but, THANK YOU very much!, I think you have set my head straight!
Batteries, electric supply on a boat is one of the most vital issues and not a subject to take chances with.
Batteries that are F*****U* can gas, can spill acid all over the place, can blow up in your face and most of all: let you down when you'd need them most.
It was very intersiting to listen to what you had to say, I do appreciate you taking the time and investing the effort to explain something you obviously are an expert at and which is self-evident for you, to a stubborn old f**t like myself!
Highly! (and I mean it, because I lack that patience, *sigh*) Appreciated!
THANK YOU!
....anyways: Tomorrow I will write down how they are connected, disconnect them and remove them from the boat - followed by starting an online search where to find Trojan 6V Batteries in Mallorca, since I would preffer to replace them with the same (so I can use the old terminals, no cutting, no guessing or meassuring if and what others will fit the given space etc.) Wrote to Trojan 2 weeks ago with that very question, got a rather friendly reply that they will let me know - and since then: nothing. I'll ask them again.
But, that's a different story alltogether, so once again: THANK YOU!
