Deck Plate Key?
Hornet_UK
1 Nov 2009
Me Hertfordshire, Boat Chichester
Hi all,
I was looking through the various bits n bobs on my new to me boat the other weekend and I found a Deck Plate key. Can someone tell me what it is for please?:o
I know it must be quite important as it has a float attached.
unscrewing the plugs for oil and water fillers. I 'have also seen big ones for inspection covers.
BTW, if you remove a plug, check that the O ring is making a good seal when you replace it. If it leaks, it will allow contamination from rain, sea spray and bird poo into the tanks.
Oh so that's what it's for... I was using a ring spanner and screw driver to open the fuel filler cap.
Thanks for the advice about O rings I'll check 'em next time I'm down!:D
And while you are attit...always put the cap in your pocket and don't leave it on deck....they have a habit of rolling off and going plop in the briny...very annoying..:D
