Deck cleaning
srah1953
21 Jun 2007
Ireland, Carlingford
Hi All
I'm looking for something that will clean a deck (both non-skid) and smooth sides of cabin top. I've tried everything (well not quite everything incl power washer, that's why I'm asking) and the only thing that absolutely works is to get down on hands and knees and use a rough sided sponge and CIF. Am I looking for the impossible?
I'd be careful about using a rough sponge and Cif on smooth cabin sides, apply minimum pressure to avoid scratching the gelcoat. A "black streak remover" might help, as it contains surfactants - incidentally, caravan shops sell it cheaper than chandleries. Applying polish/wax straight afterwards will help keep it cleaner.
For non-slip decks, a pressure washer usually does the trick.
Cheap 'wash and wax' car shampoo used with the type of brush that normally comes with a dustpan works very well on many surfaces.
Be careful using an oxalic acid based substance on your topsides as run-off may well leave bleach streaks down your nice new blue boot-top to the waterline!!
DON'T ASK !! :-(
