Boathook
I'm going to fit a new deck and steaming light plus wire whilst the mast is down. The space at the back of the fitting is possibly to small for the wire joints to be there between the fitting and mast so I'm considering staggering the 3 joints as roughly shown on the black cable, using heat shrink on each joint, wrapping the whole lot and the joint will then be in the mast conduit. Is this a sensible arrangement or is there another method ? I'm not going to pre-construct until I have checked the fitting on the mast, etc in case there is room.
