Sofus
New Member
Thanks to a previous advice I have now finished laying Coelan on my decks. It turned out to be a hair raising experience as the wind constantly decided to offer autumn leaves as an additional ingredient. However, I have now finished the 6th layer and the final (silk matt) will be put on tomorrow. It looks pretty good. I selected the red primer, and after a lot of sanding and chaulking, it turned out to be a good choise. It remains to be seen how it will behave under the strong French sun next summer but I am quite confident.
My next project will be the bilges and the space below decks. As my boat is a traditional Briton "misanier" it does not have much space below decks. In fact, some areas are inaccessible (unless I remove the engine which I will not at this stage). The "interior" has been treated with a substance based on some kind of oil containing what seems to be tar. I have painted what I can get to with International Yacht primer and Danboline. What shall I use (if anything) in the areas I can hardly reach? It is possible to spray paint (or whatever) in the far away corners/areas, and the Coelan people recommend that the decks should be painted on the underside to prevent vapour/humidity to get out from below. Is this a good idea? Should I spray the below decks space with paint or some kind of oil? What do you old salts recommend?
Regards,
Sofus
Regards,
Sofus
