TonyJones
README FIRST.
What Now Skip presents awkward boating scenarios for forum members to discuss. When a suitable period has elapsed the author will comment on contributors' suggestions and offer his own solution. Forum members are then invited to comment on that - preferably in a polite fashion. An expanded version of this solution, plus extracts from forum contributions will appear in the next issue of MBY. The purpose of What Now Skip is to give contributors the opportunity of learning from each other's experiences and opinions. Please bear that in mind when posting.
December? Well this will appear in that issue which hits the bookstands early November. And we are nearly in October now!
Another boat handling conundrum.
You are visiting a waterside pub restaurant a mile or so up a picturesque tidal river. When you arrive the pontoon is full and the only available berth is between two piles on the edge of the narrow fairway. No problem: the pub launch will respond to a hail and come and pick you up.
The piles are No 1 and No2, being the most N'ly pair. They have mooring rings running on vertical poles with retrieval lines to the top of the pile so you can haul them up.
The river at this point runs North/South. There is a N'ly force F2 blowing. The ebb has about an hour to run and the river flow plus tide is producing a current of about 1.5kt. However, water depth is not an issue.
Unfortunately, a 17ft open dory is occupying the slot, made fast fore and aft by light lines which are looped through the rings, taken back on board and drawn bar tight. If you try a conventional approach you will elbow the dory out sideways, almost certainly breaking his lines and casting him adrift.
Your boat is a twin engined 40ft flybridge cruiser with a bathing platform that extends about a foot aft of the transom buttresses but is also about a foot narrow then the transom.
Your crew is new to boating and indicates he/she is unwilling to climb into the dory to slacken off its lines. So you are effectively single handed. Your job is to moor between the piles without damaging the dory or casting it adrift. What Now Skip?
Best wishes
TJ
Best wishes
TJ
