Interlude
Has any forumite experienced a blown alternator regulator or diodes due to a battery disconnect when the engine was NOT running?
I am well aware of the warnings re disconnecting batteries when the engine is running, said to destroy electronics, presumably due to over voltage or "back EMF" transients.
The setup is separate start and house batteries, VSR isolated etc. Sterling pro digital charger permanently connected to both battery banks by separate terminals on charger (as supplied by boat builder). When topping up the house batteries last week, I found a loose cable on the house bank - which was connected to load (and solar charger) at the time. When reconnecting the loose connection, I accidently left the connection to the Sterling pro digital charger off, as the cable fell down beside battery. (Note to self - must turn in electricians licence - shouldn't be issued to idiots!). Next time out, with this cable still disconnected, the alternator had failed. As the warning lamp does not trigger the audible alarm, we noticed only after several hours on engine when I checked the battery voltages.
I never liked having the charger permanently connected to the battery banks, and have disconnected it before fitting a new alternator, having verified at the local auto electrician that the old one was US. Now all working as intended, but I would like to know why the old alternator failed under these conditions - it is a little too causal to be coincidence.
Any thoughts?
Any thoughts?
