PetiteFleur
Went to the boat last week on it's mooring to remove the canvas prior to lift out - one battery was completely dead. Removed today and took home to charge. Tried the small Cetrek charger which did not even light up, checked fuses and sockets all OK so dug out the ancient larger 10A charger of many years vintage. Connected up and nothing - left for a couple of hours when it showed about 3amps, good I thought, it;s charging. I then moved the battery to make more srcure on the bench and reconnected the charger - nothing so I shook the battery when the needle shot up to maximum, there was a click and the zeroed, repeated a few seconds later. I turned thye power off.
Is it totally dead? It's exactly three years old, regularly kept on a maintenance charger over winter and gave no problems this summer. Standard 110A Leisure battery with the common Off-Batt 1-Both-Batt 2 switch.
