snoozydude
Active Member
Maybe this will be an image.
http://img245.imageshack.us/my.php?image=imgp2401xm4.jpg
I discovered on my last haulout I am experiencing a lot of de-zincification of my prop ever since I moved to my latest pen berth. Tips of the prop blades are brittle and the prop is very pitted and blotchy.
The boat has never had an anode that I know of, though it may well have
corroded off before I purchased her as she was in poor condition and
the electrics were in a mess. I turn off all electrics when not sailing. (she is sailed a few hours every weekend).
I never connect to mains power however some of my neighbours are
constantly connected.
Hull type GRP.
Drive train.
IGM10 - Gearbox - Fixed coupling - 20cm bare shaft - PSS seal - 30mm
bare shaft - 3 blade prop.
>check for potential differences (voltages. millivoltages) between
ships components in contact with the water
From the above advice from another post I expect I could do this with a multimeter by checking between shaft and engine block where I should see a significant potential, the cause of my de-zincification (assuming the block is earthed).
How to fix.
Hanging an anode overboard - so how does this work?
Suspend an anode close to the prop?
Does the anode need to be connected via a wire to earth of just hung on a string?
I do not suppose putting an anode on the shaft aft of the gearbox coupling inboard not in contact with the water would do anything would it?
Any other suggestions until I can put on an anode on the small 30mm of bare shaft forward of the prop would be much appreciated.
Hull type GRP.
Drive train.
How to fix.
