Greg2
I have just fitted an Eberspacher heater matrix (I think they may be made by Isotherm with an Ebby badge stuck on) to take heat from the engine to warm the cockpit and de-mist the windscreen. The unit is mounted low in the boat in the engine bay (has to below the coolant header tank) with ducting runs of between approx. 2m and 4m (maybe 5m for the longest) all of which is lagged. Went out on the river today and the engines ran up to operating temp (80 degrees), which is fairly constant on the river and at sea cruising speeds. I was disappointed to get only lukewarm air from the vents and whilst it cleared the screen (so not all bad
) it didn't add much in the way of warmth.
Not sure if anyone had experience of these systems but the question is can I get anything warmer out of the system or is 80 degrees simply not hot enough?
Interestingly the spec for an Eberspacher Hydronic water heater (for heating systems) says it heats the water to 80 degrees so the temp may be okay…
I should add that the coolant supply pipe was hot and the return pipe cooler so the water circulation appears to be okay...
