Day skipper or Yachtmaster?
Woopee I'm on you're ignore list so I get the last word, what a bonus!
You have spent 2 days arguing too, and you were in the wrong!
We tried that, but you were not prepared to listen and continued saying the wrong things.
I didn't make an arse of myself, I gave up trying to explain to you that a boom preventer doesn't stop a boat from gybing, which it doesn't.
Have you considered joining them? We could do with some peace and quiet from morons like yourself being so argumentative :p
1) Hmmm ... not sure what I was supposed to arguing about ... apart from saying that ok the exam has been renamed but its the same thing with a different name. You seemed determined to make some sort of point in order to prove I was wrong about something or other.
2) You gave up trying to explain a boom preventer does'nt stop a boat from gybeing. I wondered if you were getting confused between a boom brake (i've actually got one in a box somewhere given to me by Claymore cos its a waste of space) and a gybe preventer BUT all your descriptions related to gybe preventers not boom brakes and you you did refer to boom brakes in your post. So we were definitely talking gybe preventers which you insisted did not exist and even if they did they would not prevent a gybe cos either the rope would stretch enough for the boom to whip round , or the rope would break or the forward cleat would rip out the deck.
It was pointed out to you in great technical detail why all these points were incorrect by numerous highly experienced people but nope LustyD knew better.
here's a relevant quote from the thread
Quote:
"Originally Posted by lustyd
It might or might not. In ideal circumstances it will hold long enough that the problem goes away, or even better will slow the boom as it goes accross the boat (there are braking devices on the market for this).
Sadly physics is not on your side here if you have a sailboat since it's pointy at the front, meaning that you cannot get a useful angle to stop the boom from moving completely no matter how tight you winch that handle. The forces required, thanks to this angle, are greater than most ropes could cope with so more than likely your rope will snap and the boom will be moving even faster. If you use rope strong enough to not snap, your deck fittings will probably rip out and then you have a boom followed by a projectile.
The reason I continue arguing on this is precicely because people such as Angele believe the rope will stop the boom moving - it won't. Far better to educate people on the real use of the piece of rope and where it helps and when it's likely to fail. When at sea having the best information is more important than the best kit."
I responded:
This really is such utter tosh!
Whilst I was doing my pull ups in the garage I saw my climbing ropes and it dawned on me what complete and utter rubbish you are talking!
eg a stretchy climbing rope like the Beal 10mm Tiger has a static elongation of 10% and a first fall elongation of 37% (ie from zero tension to big load), climbing ropes are designed to stretch to absorb force so the climber does'nt die. Static (or semi static) ropes like pre stretchetched polyester sheets are about 5% stretch see http://www.riggingandsails.com/pdf/marlow-info.pdf
Now on a 35 boat with a 10 ft boom out at 90 degrees , you will need c 10/(12+12+12) ie 28% stretch to get the boom past the mid point. That I suggest is ridiculous.
Now as far as ripping your cleats out and projecting catapultlike at the crew .. well quite frankly if that's what happens on your boat , you're well overdue a bit of maintenance!
The breaking strain of prestretched 10mm polyester is roughly 2 tons
http://www.jimmygreen.co.uk/p/techni...g-strain-guide
and if you've got 2 tons of weight at the boom end of a 30 odd foot boat then you're doing something wrong .. one of the reasons you've tensioned the thing in the first place is to avoid shock loadings!"
3)you said:"We could do with some peace and quiet from morons like yourself being so argumentative "
No I'm not going to shut up. If people post rubbish then it is right that is pointed out. After all this forum is for the exchange of information and often people who are learning are seeking information. It is only right and proper that incorrect information is corrected.
You might also like to refer to the T&C of the site which prohibits personal abuse. Calling someone a moron is definitely personal abuse (I know I used the word first but that was to describe the quality of the post, not the person so its not personal abuse).
Please stop guys! Started off as an interesting thread that has now confused the hell out of me. Just block everyone you disagree with and move on. This has all turned into a "no rafting" sign - always a red rag lol.
I suppose I could stop reading this thread, but there is always a chance that something useful would be said to close it. :-)
Tony
Ps: What I am much more interested in is knowing what the weather will be for the rtir, but I guess that's an entirely new thread! Looks pretty calm to me.
What I'd really really really like to know is what you thought i was referring to by a "CS practical exam" before you arrived at that interpretation?
Not a clue at the time, since that exam doesn't exist.
I'm really disappointed by you two getting so hung up over me referring to the exam by its prechange name .. so hung up in fact you've devoted 2 days and numerous posts to it.
One simple line would have sufficed:
"the Coastal skipper exam has now been renamed the YM Coastal exam"
Likewise, you could just have said "Whoops, I meant the Yachtmaster Coastal exam" instead of tying yourself in knots, mixing up courses and exams and in the process potentially confusing anyone new to the system who didn't know about the changes.
I know there's quite a few highly experienced and knowledgeable people who do not post on this forum precisely because of moronic behaviour like this, and the place is a poorer place without them.
Presumably the "highly experienced and knowledgeable" people don't mix up the YM Coastal exam with the Coastal Skipper and then get all snotty with the people who point out their error.
Tony
Tony,
if I may dodge between the flailing elbows for a moment, no guarantees mind but the week-long forecast on Gardeners Question time reckoned ' cool & unsettled but heading towards better conditions and lower winds for the coming weekend '.
I certainly hope so, not in the race but it would be nice to get the boat out.
Hope this proves correct & have fun all,
Andy
Tony,...cool & unsettled but heading towards better conditions and lower winds for the coming weekend '.
Andy
Thank you seajet. I'm reckoning F3 from the north against current synoptics. Shame the cruising chute is covering the patio as a rather attractive Italian style shade device. Looks like I'll come close to last again - but I don't care, it will be fun!
T.
Good heavens! I've returned to this thread (I am the OP, in case anyone's forgotten!) to find pitched battle has broken out!
With the best of intentions I'm sure from those who have contributed, I'm now faced with wading through numerous posts full of acronyms (and acronimy!) to try to discover exactly what advice I should take or ignore, what course gives an accepted certificate or merely a certificate of attendance, what pre-requisites I may need, or be advised to have, and possibly other confusions that a first reading of the thread's development have only hinted at.
Can someone please tell me if any of the following is incorrect: -
I am resolved that I will undertake the shore-based Yachtmaster theory this winter. This will enable me to learn all the relevant and necessary theory short of astro-navigation that I will need, and will give me a certificate of course attendance, but no formal qualification.
Next summer I intend to do a practical course, either day skipper or coastal skipper. I am unclear on the difference, I assume the coastal skipper is the "higher" of the two, and would prefer this. A degree of experience is required (?) for either - I have no RYA log book, and although I have crewed and kept watch on coastal passages (Sunderland to Nairn with return voyages, Nairn to Orkneys return, skippered charter Scotland to Northern Ireland via IoM, one week skippered charter Western Isles) I have never skippered off-shore - my sole experience as skipper is on the Norfolk Broads. Having said that, within the limits of my knowledge and experience I believe I have the confidence and necessary character attributes to fulfil the reponsibilities of being in command. I expect this course to give me a formal qualification which will enable me to at least undertake bareboat charter for flotilla sailing or similar.
Please help to resolve the confused state I now find myself in!
Yes. You have a choice of two theory courses: Day Skipper and Coastal Skipper / Yachtmaster Offshore. There is an even more basic one, but that's not what you need, I think.
The syllabus for the DS and CS/YM courses is very similar, but the second course covers things in much more depth. If you have some boating experience and are fairly happy with maths (using graphs and diagrams as well as doing arithmetic) then I'd suggest going straight to CS/YM.
Next summer I intend to do a practical course, either day skipper or coastal skipper. I am unclear on the difference, I assume the coastal skipper is the "higher" of the two, and would prefer this. ... I expect this course to give me a formal qualification which will enable me to at least undertake bareboat charter for flotilla sailing or similar.
Others know these courses better, but as I understand it DS will also get you an ICC, which is what most charter companies want. Neither of the courses you mention gets a qualification: instead you get a course completion certificate. The CS course can also be used as preparation for the Yachtmaster Coastal exam, though that is a separate test and I think is carried out by a different instructor.
From what you write, and from what I know, I'd suggest the two Coastal Skipper courses.
Its an exam, carried out by an examiner from the RYA list.
No , the exam must be conducted by a examiner on the RYA list. Even if the instructor is also an examiner he/she may not conduct the exam.
Thanks. Does that apply even if the exam doesn't immediately follow the course? For example, if I took CS Practical at a small sailing school with one instructor/examiner, could he examine me on it six months later?
Having experienced some of this perhaps I can chip in. I hadn't sailed for nearly 40 years before starting again last year, so I did my Day Skipper practical which was assessed at the end of five days by the instructor and I was awarded my Day Skipper ticket. I then did another couple of weekend courses on close-quarter boat handling and sail trimming. After a couple of months crewing, including a couple of race weekends I asked a YM instructor whether I should start preparing for the YM Coastal practical exam (always conducted by a YM examiner, often at the end of a five day YM-C preparatory practical 5 day course) and I was advised to just get more miles and experience before going straight for the YM Offshore exam (with or without a preparatory course prior). I had already been reading up on Col Regs and had home-studied the RYA navigation books, so I was fairly happy about those elements.
I'm hoping to take the YM Offshore practical exam in the autumn (will have done in excess of the 2500 Nm, requisite night hours and the 2x 60 Nm voyages as skipper) and I will probably take a five day preparatory course just before the practical exam just to make sure that I can get help from the instructor about anything that I might need to improve in advance of the examiner coming on board.
My understanding is that the YM Coastal exam is a 'softer' version of the YM Offshore exam, but still requires a good knowledge of Col Regs and practical navigation, as well as skippering skills. The DS is more a case of making sure that you're reasonably safe to sail by day in inshore waters. Whether you start at DS and progress through YM Coastal to YM Offshore, or miss out DS or skip YM-C will really be down to your capability and confidence.
Just my thoughts.
If you feel confident about your abilities, you don't have to take any courses and can simply book the exam of your choice, arrange a boat and crew and welcome the examiner on board.
Can that examiner be the instructor who ran the preparation course? I'd heard not, but that could be false rumour or my misinterpretation.
Never heard of any Instructor then being the 'Examiner' for his own students - this only happens on Theory courses & practicals like DS & CS, not the RYA/MCA practicals.
No!
"If you are considering getting a qualification to demonstrate your sailing or motor cruising ability, the Royal Yachting Association Yachtmaster Offshore qualification is without doubt the most respected Yachting and Motor Cruising qualification in the world. The Yachtmaster Scheme is administered by the RYA on behalf of the Maritime and Coastguard Agency. Yachtmaster Examiners are independent assessors and cannot be involved in the training of candidates. They are therefore able to be completely objective when assessing candidates."
For those sceptical about fast track -
http://www.rya.org.uk/coursestraining/exams/Pages/Fasttrackyachtmasterexam.aspx
What is reported upon by the Examiner
http://www.rya.org.uk/SiteCollectio... Training/Exams/TRA Practical Report Form.pdf
Ah, right, so examiners don't do any teaching at all? I hadn't realised that. Thanks.
There's a hint of the Mandy Rice-Davies there. He would say that, wouldn't he?
I'm skeptical about the Fast Track qualifications because I am not convinced that someone who has spent all his time in one boat sailing to the same harbours in one small area can have enough breadth of experience. Of course a good sea school should take account of this ("OK you two, this is a Corribee. See you in Dublin.") but there doesn't seem to be any mechanism to ensure that they do.
I note that a recent fatal accident occurred in a yacht skippered by a very young YM Ocean. I shall be interested to read the MAIB report on that.
Which "recent fatal accident" was this one?
Which part of the "recent fatal accident occurred in a yacht skippered by a very young YM Ocean.", are you concerned about? Fatal accidents occur even amongst mature & much experience skippers, so I hope the age of the YM Ocean isn't being snidely insinuated as a factor.
PM sent
No snide insinuation intended, merely curiosity prompted by a news article. I certainly haven't made up my mind (how could I? I know very little about the case) which is why I'll be guided by the MAIB report when it comes out.
