stevensuf
plus one on those cutting discs i had 3 shatter just trying to enlarge speaker wholes in the fiberglass, they didn't embed in anything though. the metal discs with diamond tips shatter far less frequently.
You only need one tool.
This is it., does everything you need.
It's a chisel, it's a saw, it's a sander. Clean and safe.
http://www.multimaster.info/en_uk/
I bought their fibreglass reinforced wheels which last much longer and are cheaper in the long run...
On the subject of dangerous tools, I once tried to power-plane the side of a small block of wood while I held it in my hand. 30 years later, I still don't have fingerprints on the two fingers that went into the plane.![]()
Oh yes. I had a frightening experience with an angle grinder. It was switched to "run" and jammed in a piece of angle iron I was cutting. It nearly broke my thumb as it wrenched out of the workpiece and corkscrewed up in the air.Last year I had a 115mm skinny disc trap and shatter, lost control of the grinder and it started to chew my crutch up. Faced with singing soprano, I stopped the remains of the disc rotating with my hand. Dangly bits only just bruised and abraded, but I needed 7 stitches in my hand
The boys even had a sweep on how many stitches would be inserted
