ylop
I don’t think anyone was implying it was loose change - but a replacement “system” (horseshoe+danbouy+light) is likely to be getting towards that direction anyway.But maybe Stg220 is just loose change to some.
Except when they get so old they crumble away, or the telescopic style get kinked or as I’ve seen on many boats people keep adding bungees etc to keep it all under control - delaying deployment if needed. ALL approaches have pros and cons, I think you are probably right that a traditional pole, plus horseshoe and good light are robust if used as the manufacturer intended, and if given the same TLC as an inflatable will last well… but a wander round any marina will see plenty which clearly never get a second thought.There is very little to go wrong with the traditional pole
I don’t think anyone said it was - but the OP needs to replace his horseshoe which has also been destroyed by the sun, and unless he’s been lucky that probably also means his light too.and if the flag deteriorates surely it is not beyond the wit of man, or woman, to make a new one
the problem with stuff that gets stored down below is people rush/forget and then suddenly someone is in the water and the bloody danbouy is not where it normally is. I’m sure you are diligent so that would never happen. It also adds a few minutes to setting up and packing down the boat between use. Those things are what discourage people from actually using the boat more.and/or store the Danbury down below when not at sea.
I would say the cheaper “poles” probably aren’t a whole lot better. If you really want to find a casualty in 50 knot winds and big seas perhaps it’s time to really go “hi tech” with ais transponders etc?Before singing the praises of self inflating devices I would encourage people to inflate their device and try ir in 50 knots of wind with big seas. They do have a worrying tendency to lie flat.
