GDST
New Member
Has anyone replaced a damper drive plate on a Merry Fisher 635? Engine is Volvo Penta TAMD 22 PB and gearbox is Volvo HS 25A-A. I want to know if it can be done without removing the gearbox.
There is about 5 inches behind the coupling i was hoping to leave the bellhousing attached to the gearbox and slid both backYou have to remove the gearbox from the engine at the bell housing joint. The issue is whether there is enough room to slide the gearbox back to access the damper plate. This is determined by the amount of space aft of the coupling and clearance behind the prop. My guess is no and the normal way would be to either remove the gearbox from the boat or pull the engine forward. The former would seem the easier thing to do.
