Refueler
I have seen 2 Centaurs that had been fibreglassed straight over old oily filthy danboline bilge paint, nothing is going to stick to that! If you grind back to clean glass Poyester will stick perfectly, or Vinylester which approaches epoxy in performance but with ease of use of polyester.
One thing people who advocate epoxy often dont realise is that the glass reinforcement should have an epoxy compatible size (adhesion promoter), Glass intended for poly or vinylester has a different size.
The gauge or as usually stated the weight per area of glass matt is decided on the job it is to do - not the resin to use ... and having done a lot of glassing and had instruction from Strand Glass ... as long as the resin is of the correct fluidity - the matt will wet out.
With Polyester of course one of the biggest hurdles is the working time ...... so you need to work with thin matt to ensure wetting out before resin becomes unworkable.
Epoxy can be of course in far longer working time form ......
