Daydream believer
Dylan
I have 2 folding bikes I bought from mailspeed. They are OK but a couple of points to note
1) On cheaper bikes lots of gears tend not to work properly & you end up only getting access to half that many as the gear change is rarely precise enough. So 7 gears is not much of an advantage over 3 as it would be on a better quality bike
2) For taller persons the seats are rarely high enough - regardless of manufacturers claims- so the cyclist ends up struggling to ride properly as he cannot get his/hers legs straight enough. My solution was to buy a longer stem. The standard diameter of which is normally 25mm. I had a devil of a job getting one & even now it is not enough. In addition the frames are not so stiff as a full sized cycle so they flex & this is worse on a folding cycle especially with a longer stem.
So if for taller persons check the stem diameter & availability of longer ones. Some have 30mm stems & this may be an advantage
3) A padded bag is useful as a cycle can be a devil of a job to get out of a locker. Mine comes out via the heads & whilst it may not worry some, it is very easy to snag or scratch doors etc
