DAB on board
I have DAB in my car and very much appreciate it. I installed a car radio with DAB on my fibreglass boat but it would not pick up any DAB stations. I am no aerial expert. Googling revealed the need for a ground plane, a plate of metal to act as ground/earth. On a car this is the roof. Part of the little DAB stick on aerial attaches to the roof after you scratch away the paint at one point. At a boat show I spoke with an aerial supplier who advised that a powered aerial of a certain type would help and avoid the need for a ground plane on a boat. I bought one and indeed it improves reception a little but it's still very patch even around the Solent. Not a success. I'd be interested to learn the experiences and advice of others not using aerial splitters.
How do you cope with mono? Are you deaf in one ear? And what about the ridiculously restricted audio bandwidth? I guess you won't notice that if you're much older than 50. I assume you power it off mains, or the boat battery bank, because a set of D cells don't last five minutes.
I completely agree. It doesn't help that DAB isn't available in most the areas that I sail, and few DAB channels are available where I drive.
Digital by its nature is on or off .. you have a signal or you don't .. so in areas of poor reception you're stuffed.
DAB was a good idea, but reducing the bit rate to leverage more channels has ended up with appalling quality .. which is exacerbated when there's a poor signal.
