Dog's dinner
New Member
About 18 months ago our heat exchangers and air coolers started leaking salt water around their end caps etc. We had them removed stripped cleaned with Rydlyme and reassembled with new O rings and some type of Volvo sealant as recommended by volvo parts dept. Managed to clean up the starter motors.
Luckily the heat exchanges seem fine but disappointingly the end caps inlet end on the air coolers have started to show white deposits around the joint again.
These are the original end caps part 3583628 which is some type of bakelite material.
I have read Spannermans Post 2012.. Well known fault replacement cover made in brass..
I have found pictures of brass ones in America but no part number.
But the local volvo dealer showed me the new ones part 22092538 which are the same as ours a bakelite type material.
Question : Shall I clean and put the original end caps back on or shall I buy the new type end caps and what has happened to the metal ones referred to on this forum.
Has any one fitted the metal or new type ones ?
