ShipsWoofy
I am trying to build a new power panel and have a lovely sheet of ally perfect for the job.
I would prefer rocker switches to toggle which makes the job far harder.
Given a fairly comprehensive tool kit incl. > 750W drill, dremel, jigsaw, grinder etc. Is there a special tool I can buy to assist or use with what I have. I have a pad saw (after advice on here) which will take hacksaw blades, but imagine that would be a dreadful method of bent blades.
The holes will be approx 30mm by 10mm with little room for error.
If you were considering tackling this what would you do, there are going to be up to 18 so I am looking for a speedy but accurate method.
Or would I be better marking them up and getting them cut in a workshop. All other holes are round so easy enough to manage.
Though I have seen some round toggles but they require a 22mm hole, how do you cut a 22mm with a 1/2" chuck hand drill, I could do 10mm and a cone grinder but it would be a horrible job.
Thoughts anyone?
Thoughts anyone?
