robbieg
I've got an ST4000+ pilot connected to a Navman 5500 via NMEA which gives it postion data. I want to connect the pilot to a Raymarine radar via a seatalk cable. This should allow the radar to get postion/heading data.
Its quite a long cable run between the 2-approx 10 m. What I'm thinking of doing is getting a short seatalk cable with plugs on each end & cutting & extending it. This will make running the cable easier & seems a lot cheaper than buying a long Seatalk cable.
Questions are:
1. Anyone see why this shouldn't work?
2. Any problems with a long cable run-do I need to feed 12v power to it to "refresh" it in view of its length?
3. Is it necessary to use shielded cable to extend-the seatalk cable-I'd like to just use 3 core electrical since cheaper but suspect I'll need to find some sheilded-any thoughts?
Thanks.
Questions are:
Thanks.
