petem
Couldn't you have cut it on a laser before curving it?I am making a new curved windscreen section for a motorboat. I used the old one as a template, make a buck using ali sheet and grp, with a hot air gun I mould the new sheet over the buck.
So far so good.
Now I need to cut out the exact shape of the screen from the big sheet I've moulded.
A multi tool with an abrasive cutter makes a gooey mess, as does a toothed cutter.
Jigsaw makes a gooey mess with coarse, medium and fine blades.
A hacksaw blade by hand works, but will take me days.
A grinder with a 1mm slitting disc makes a sort of hot melting plastic candyfloss fly everywhere.
A grinder with a 36 grit flexible disc works on the edge, which might be ok for final trimming. But I have a lot to remove.
Any suggestions?
