dunedin
I think I need to cut an access hole in the thin (circa 1mm) GRP/plastic cabin roof liner to access some nuts holding the GPS receiver. Needs to be around 12cm diameter or square to get a hand in.
What is the best way / tool to do this?
- I suspect that a Jig saw would be too powerful/ rough to cut this cleanly (and don't have one on board). (And the emergency rigging cutting angle grinder is clearly staying in its box !!)
- is there a cutting tool that can be attached to a dremel type tool?
- other suggestions?
Also how best to cover the hole. Probably need to source a small peice of stiff thin white plastic sheet - but not a meter panel.
