Boater On Thames
I am going to cut a big hole 50cm X 90cm on top of the 200-gallon aluminium diesel fuel tank on board. Is it dangerous to do so? It's empty, but not wash yet because it's very big with only a small hole for the fuel level sender. A bit of grease inside but not too much, and very little diesel on the bottom far corner can't pump out completely. I have a circular saw and a jigsaw. I am planning to put a vacuum cleaner to suck air from the fuel level sender hole while the outside fule inlet open. Any advice to keep safe to avoid fire or explosion? Many thank!
