Cutting a Glass Mirror
gardenshed
1 Jan 2006
13:44:00N 100:32:00E
Not really a boating question but I know that there is good expertise here on the forum:
I have a mirror for the bathroom wall. I need to cut either a slot or some holes in it to allow the wires for a shaver socket to come through and for the securing screws for the socket cover to go through the mirror and secure to the back box.
the mirror is 1.0 x 1.5m
how do I cut or drill the mirror without causing a big crack or shattering it!
Tools available: power drill, dremel, hand tools
I think you can try drilling it underwater, but use a non-mains power tool in case you get fried.
You can cut class underwater with scissors without cracking it, so I presume a drill will work in the same fashion.
If it doesn't work I accept no responsibility for the 7 yrs bad luck.
Dude
No guarantee, but I think you can drill glass with a hollow drill, grinding paste and low speed. With respect, the underwater method seems to have a touch of the old wife's tale about it. If it were mine, I'd take it to the local glazier.
Ed. for "hollow drill" read "short length of metal tube."
The underwater method works...take a piece of glass, a bowl of water and scissors and give it a go.
Dude
I'm amazed, it doesn't seem possible. I'm going to have a go with a spare bit of glass. Do you still have to 'score' the surface as if cutting normally, then use the scissors to sort of 'cut' along the line? /forums/images/graemlins/confused.gif
I have used successfully in the past a small "ring" of putty round the mark, filled it with water and used a masonry drill at slow speed, but only on clear glass not mirror, and it always has been new glass which is "softer" than old glass.
I have several battery operated shavers, which seem to last for a couple of month before requiring charge. Is this not easier?
