Gordonmc
I decided that, as I am replacing my propshaft I might as well put a new cutless bearing on as well.
After two hours of grunting I finally got the housing unscrewed from the sterntube. Much headscratching then went on at the chandlers trying to trace a suitable replacement. While most of the stock items are made up of a plastic material (neoprene?) in a brass liner, the original on mine was a rubber-like material pressed into the bronze housing - no liner.
In any case there is no stock item to fit the internal diameter of the housing. Best advice so far is to buy a bearing with the right shaft diameter (1 and one/eighth inch) and the nearest external diameter, then get the liner turned down to fit the housing.
My obvious concern is weakening the liner, but that might not matter if it is contained in the bronze housing, assuming it will drift in OK.
N.b. Best solution would be to replace the housing with one with a non-bastard size diameter... but that means replacing the sterntube. Soddit.
Any thoughts/advice?
