cutlass bearing
I am looking for a new cutlass bearing for my Gib'Sea 282. Cutlass bearing is 25 mm (shaft) x 40 mm x 120 mm. The agents I have contacted cannot supply one although T Norris can supply 100 mm. I would prefer to get the same as original or longer. Can anyone help?
brianhumber
30 May 2001
Sussex
Try looking at Countrose web site. They make them and will sell direct so you cut out the middle man.
You can get spun resin casing or traditional brass.
I would stick to Brass cause its easier to tap out when you next change the bearing.
