Tranona
Acomposite bearing is usually glued in with epoxy - no heed for grub screws. To remove if it ever needs replacing you heat it up to soften the epoxy.
If you can feel a ridge 4 or 5 inches in from the prop end it's probably the bearing outer shell.Done mine in the summer. Rubber part had worn to such a degree there were no grooves left and it just fell out when I took the prop off. Was really difficult to discern whether there was more to come out of the sterntube. Eventually I started sawing with a hacksaw blade, actually quite easy, the metal was soft brass. Couple of taps from inside and the remainder of the cutless bearing appeared and was easily withdrawn.
Not unless your boat is built in aluminum and there is an electrolysis issue, I should think ther would be no dif.Just changing my cutlass bearing, is there any benefit or reason why I should or should not change from brass to composite ? Looking at Exalto and Norris
Composite shells expand in water, so a clearance is built in to allow for it. There will be a small 'slop' when initially fitted that should disappear after launching.Just changing my cutlass bearing, is there any benefit or reason why I should or should not change from brass to composite ? Looking at Exalto and Norris
My Jaguar / Catalina 27 has a 1" shaft with 1⅞" outer sleeve, 3½" long. Definitely a cutlass bearing, don't think there is particularly a rule or standard on these.Standard cutless for 1" shafts (double check it is not 25mm!) have outer shells of 1 1/4", 1 3/8" or 1 1/2" all 4" long so I don't think your tube had a cutless. Best to talk to h4marine.com about having a composite bearing made exactly to fit your tube and shaft.
