I recently fitted a new prop, shaft and cutlass bearing (in a P bracket)
On first running the engine afloat and going into gear, there was a terrible juddering vibration. Stopped everything. Nothing round the prop, checked engine alignment OK. On rotating shaft by hand the jerky juddering could be felt. Put it all back together. No change when in gear. Let it run for a few seconds and juddering got less until it stopped altogether. Question is....Is this normal? Do cutlass bearings need to run in for a few minutes...or new shafts for that matter? should I have greased the shaft / cutlass first?
Any help or reassurance would be helpful.
John
John
