richardsussex
I am helping a friend with some maintenance on a shaft-drive internal-engined cruising boat approx 13m. The Cutlass bearing/stern gland is connected to a small header tank reservoir by a tube. The liquid in the reservoir is a red colour, similar to ATF, and does feel "oily". There is no indication as to what the fluid is.
Unfortunately the boat is a one-off aluminium craft from a now defunct French manufacturer so there is no information available.
There is no leak and all seems OK at the moment. All we want to do is to keep the tank topped up. I don't want to cause problems by putting in ATF it is expecting, say, Brake fluid or mineral oil, or some specialist hydraulic fluid.
I have only ever seen water-driven connections or a grease pump to this part of a boat so am a bit mystified.
Any ideas as to what I should top up with gratefully received
Thanks in anticipation
