dustywings
I need to replace one of my cutlass bearings and was hoping to use one of those pullers that allows it to be done without removing the shaft but when I look at the P bracket it is designed, I assume for streamlining, with an enclosed design on the forward facing end as you can see in the photo:
I thought I would ask the forum if anyone has found a way around this with this type of P bracket, even by removing the shaft if I need to use a hack saw and cut down the length of the cutlass bearing the enclosed part of the P bracket will be in the way... do I cut through that too?!
