a sharply pointed front end is a key design feature to get the anchor to set quickly. I wonder if Rocna will be willing to comment on how many other Rocnas have bent their snout ?
Good thinking, Lemain!
Meantime, I continue to use it, and pray that the shank is made of sterner stuff than the fluke. So far it has continued to set in an istant and hold as usual.
I could take off the curl: no need for a grinder, a file would do (or perhaps just the ship's knife?) but that removes the galvanising too.
I'd take it back, demand a refund and buy a more robustly made anchor.
This example reflects the doubts I have about many different gee-whizz anchors as they come along every few years: designs which dig in effectively often do so at the expense of robustness. It's almost inevitable: nice sharp edges and thin flukes can never have the strength of a lump of decent, god-fearing forged steel
Hi Keith
I suspect you'r right about it being better to bend than break, but if the weight of the anchor is as recommended for the size/weight of the boat, should it bend or break even in a blow?
As a recent owner of a Rocna, I'm interested to know what size anchor is it, what weight /size is your boat, what was the tide /wind strength acting on the anchor before you weighed it?
Could we see a full picture of the anchor to confirm it is what you say it is?
ta
Scotty
Fortress anchors seem to do OK and they are sharp.
When we first arrived in the Med with a genuine Bruce we had real problems with the hard sand. I came across a fellow with a modified Bruce - very rusty. He explained that the trick is to sharpen it with an angle grinder. I never did, though he was probably correct. Instead I bought a Delta and am perfectly happy; we spend 60 to 90 nights a year at anchor and sleep pretty soundly now.
At Rocna we pride ourselves on the strength and reliability of our anchors.
He will be able to assist you in having your Rocna replaced or repaired.
There you go Lemain (and Piota)... challenge taken up: as an owner (satisfied so far) I'd like to see what happens. Keep us informed! /forums/images/graemlins/smile.gif
