Cups are spinning but no wind speed on display
sealegsjim
18 Dec 2007
Windermere
I have a B&G Zeus chart plotter and Triton displays. The display shows wind direction but no speed. Could it be a "loose wire"
or is it likely that the wind speed sensor is kaput even though the cups are spinning
Thanks for any help
It could be a failed connection somewhere or a failed circuit inside the masthead unit.
The only way to find out is to test the output at the terminal block at deck level. If there is no output there then you will need to take the MHU down to test it and the masthead connections.
Richard
