superheat6k
Again good prompts. Today I am going to check the fuel systems are primed and this will include a check of the lift pumps.
I also will use a temporary connection direct to the fuel solenoid from the opposing battery during start up.
If this does not get them started then I will remove the solenoid plungers.
I also noted the comment that energise to run solenoids are less than ideal. I am going to look at a mechanical solenoid that could pull the stop leaver. The existing ignition switches already have a disused stop position, so connecting these would be simple.
Separately I am ordering two new batteries so I can double the port / house to 220AH with 1600cca, and for the stbd a truck battery with 1000cca.
