jfm
Out of curiosity, doesnt sea state account for more than 10 pct? I mean, if A to B will use 1000 litres, are you happy to go with 1100 litres ?
Generally the sea state makes no difference to 80 feet/60 tonnes. If for some reason I am going to punch into a big sea then I can allow the extra fuel, but my objective is to get the raw data to begin with, and then I can do the maths including the seas state fuel burn factor. Gjgm, no I wouldn't be happy with100 litres spare but if you multiplied all your figures by say 5 then I probably would (with the right instrumentation and a "plan B" if something when wrong as opposed to pure open water)given that fuel consumption is going to be dependent on sea state?
Yup, agreed, prudence and various things go into the maths when you make the buy fuel/don't buy fuel decision, but what I'm trying to do is get the best quality raw data in the first placeIs it not more prudent to buy say 1000 litres of fuel in Bonifacio to be on the safe side and not worry about your gennie fuel burn?
Thanks. See below re baffling. I'll take a look at those. Calibration is very difficult, practically speaking, on a genset that shares its fuel with main engine tanks of this size. I really need n2k output though other outputs can be used with convertersIf the baffling in the tank is good, then the level will not surge (much). Would an ultrasonic or optical meter give you a precise enough output after calibration ?
And even small aircraft need fuel flow system monitors with the kind of precision jfm is seeking, with a greater impact if they get the figures wrong. Perhaps something here ?...The Microflo device (other totalizers are available) gives fuel flow, fuel used, fuel remaining, and endurance, though whether the output can be integrated into one of the big Match screens is a known unknown.
I honestly get nothing like 38% variation. I have instantaneous read out on the dash of litres/mile and litres/hour and would see even a 10% variation immediately and could allow for it or fix the problemso a 38% variation....I keep 20% up my sleeve as a minimum, running in bad weather and pulling air instead of fuel on a roll,
I'm not suggesting relying on anything. I'm suggesting getting the best quality raw data to do the maths on, but given that it is electronically measured data I'd always do another "sanity check" calculation tooA lot of people rely on electronic equipment which gives you three decimal places of accuracy but on flawed date. Miles run and fuel burnt per NM is the only real data worth looking at. Work back from tank fill/miles run (through the water) data.
Yep, sorry, forums eh. It would be much easy to discuss this in a pubWell, I wasn't suggesting that the mains had anything to see with the genset fuel burn math.
Yup, ultimately I'm just trying to get the raw data displayed easily on a screen so that I can then apply whatever maths is appropriate in the circumstances. Thanks re floscan. My understanding (but only afaik so I'm happy to be corrected) is that you have to calibrate them. You fill the boat's tanks, then drive the boat for an hour or 2, then fill the tanks again and measure the fuel used from the fuel pump at the dock. Then compare that reading with the floscan measurement, then you enter a correction factor. Obviously that process cannot practically be done with a genset. The Maretron system uses positive displacement metering so this calibration is not necessary. The Maretron gear is also much smaller to fit. TBH, the Maretron stuff looks better in every respect than Floscan. (But a direct link to j1939 data would be even easier than Maretron!)Anyhow, all that aside, I did understand that you're after something better than an estimate - my comment re. the Floscan was in that direction.
Maybe worth a look, if you can't get the "real" numbers out of the Onan ECUs. Which I agree would be the easier/better way, if feasible.
Thanks ARE.Morning,
Working at PYI today, I will reply when I get back to hotel later
Anthony
Just as regards tank design, baffling, and possibility to suck air in a big sea, the pics below are my last-resort central fuel tank. As regards orientation, the second picture shows the starboard side of the tank. The bottom of this tank is 750mm or so lower than the bottom of the two other (bigger) tanks. So when I'm down to my last fuel I'm pulling fuel from the bottom of this tank. As you can see, it is quite a nice design and allows me to pull fuel down to say the last ~150 litres (the foot print at bottom of tank is about 1.5m x 750mm so every 100mm of tank depth is ~110 litres), so I do not need to allow much "sloshing around" factor in my fuel maths
