pcatterall
Yes I am a tight wad. I have lost part of a crutch strap and wonder if you can buy just bits. Its one of the plastic socket bits that is fitted to a short loop which goes over the waist strap. The crutch strap then goes under the leg and clips into it. Any sources known?
Reading the Lion MAIB report has focussed the mind a bit and I realise that one strap is not really good enough!
The report suggests that the straps will pull through with a 50 kg load so not really safe to assume that the jacket wont pull off if a casualty is being raised by the built in harness.
Is there a way to double secure the fastenings or would the plastic clips be the next failure point?
