misterg
PO fitted roller reefing genoa to our 22' venturer, but we also inherited a selection of hank-on sails, including a cruising chute. As a winter project, I would like to equip the boat to fly the chute without having to drop the RR genoa. (One broach a year isn't enough!). No spinnaker gear fitted currently.
I know I will have to:
Fit a block to the mast-head to carry another halyard (assume ~8mm)
Fit a block / fairlead to the stem fitting to attach the CS tack
Add a secod set of sheets with turning blocks on the quarters for the CS (again assume ~8mm).
I would also like the option to fly the CS with a poled out the genoa for dead down-wind sailing (Anglesey -> Conwy 90% of the time). Boat has fitting for spinnaker pole on front of mast, and a loop that looks like it's for a pole up-haul.
Questions:
Does the cruising chute tack line *need* to be adjustable, or is it sufficient to tie it off to the stem-head?
Should I fit dedicated cleats for the cruising chute sheets?
Do I need a pole up-haul to pole out the genoa? If so, should it go through a block on the mast? where's the best place to cleat it off?
Do I need a pole down-haul? where does it need to run to, and where should it be cleated off?
Are the suggested line sizes OK?
Any opinions on whether the whole thing is worthwhile?
We're talking pottering here, not competitive sailing, but would like to be home before dark.
Thanks in advance for any suggestions.
Andy
Questions:
Andy
