Very difficult to judge from photographs but looks like marks on the surface. Could be from grit stuck in the sole of footwear ? Have you tried cleaning ?
If not a dog perhaps some other animal has been aboard your boat?
Do u have a dog
LadyJ
My MF is 2008 and has the same markings on the non skid. I live with it and am considering fitting flexitek at some stage. Tried using crack filler but just came out after a few washes.
HTH
I had a list of gelcote repairs for Benneteau to do but after your thread I also checked the treadplate and sure enough I found a small crack in the cockpit close to the lazaret. To be honest it's hard to determine what it is I tried blowing up a photo but it's still hard to figure, I think it's cracked but I would need something very fine to probe it
What I'd like to know is it possible to make an invisible repair by reforming the antiskid diamonds?
Thanks LadyJ, I'm sure that when I show it to Benneteau they'll tell me it's my imaginationI suspect this is the same situation as mine and almost looks as if you've taken a Stanley knife and cause small scores. Re your question on invisible repairs, I had one done on my antiskid due to my own fault and it was ok but not as good as the original. Believe the job consisted of the application of gel coat and the work with a hacksaw type blade to make the diamond pattern, good job but I can always tell it is 'repaired'. Hope that helps.
Personally, I don't think either Jeanneau or Beneteau will view these cracks as 'warranty' items.
If under warrranty time and T&C it isn't a matter of their view or the ability to make an invisible repair. It would be their liability and they would have to come up with a solution. Repair, cover, layer or, if nothing else, a compensation.
Afterall Group Beneteau (who owns Beneteau, Jeanneau, Prestige, CNB, Lagoon, O’Hara, I.R.M, BH, Four Winns, Glastron, Wellcraft, Scarab, Monte Carlo Yacht and CNB Pro workboats) is the worlds biggest manufacturer and capable of doing 'anything' if they want to.
This might well be the case in an 'ideal' world, but in reality.....????
