mjkinch1
I went to clean out my raw water filters after a changed hose, noticing that there were bits of what looks like shell being tossed around when we checked the engines.
I undid the nuts OK,but the glass looked firmly stuck to the seal. On closer inspection the glass was cracked around the rim where the metal ring held it in place, and I got the impression if I tried to lever it out it would break and I would not be able to put them back in one piece.
With the ring on holding themin place the cracks are covered,so there doesnt seem any danger of a leak- but to clean the filters, I suspect the glass will need replacing.
Is this quite common? And if I do it myself over the winter is it saftety glass,or a particular kind and thickness of glass?
Anyone else had the same. You can see the raw water filters at the back in this picture with the metal rims holding the glass in place with two bolts...
