Cracked centreboard base
Bassman2
24 Jul 2020
I have an 20+ year old wooden Solo dinghy and last time I was out I noticed a crack, about 30 cm long in the centreboard casing.
I suspect that any professional repair would cost more than the dinghy is worth so I've been wondering how to deal with it. I'm not much of a DIYer, but I have some plywood left over from cutting locker tops for a CO26. I was thinking that cutting a piece and gluing and screwing over the top of the crack would do the trick. Anyone have any views?
I have done something similar with success and no ill effects. I have also used glass fibre matting, whatever comes chaply to hand.
I cracked the centreboard case on my old Merlin by over tightening the centre board bolt...
Perhaps , if you have a router, you could set it up with a parallel straight cutter of an appropriate diameter, temporarily fix a straight guide to the centre case somehow , and simply rout a deep straight channel taking in the split and the glue in an accurately machined mahogany spline. That would almost certainly be a good and tidy repair.
Or, less craftsman and more bodge, cut a wide shallow V with chisel and fill with thickened epoxy. Could also put plywood patch on top also.
Many old solos had a completely open top to the case. Capping the back of the case or inserting a filling piece for the last foot or so makes it much much structurally sound and didn't ,in my boat, impinge on the centreboard
