PeterR
So trying to talk swmbo in to heading to s Brittany for a couple of weeks this summer and want a better anchor for the islands and moribhan, but cannot afford a spade but was wondering if the Manson was worth the extra 200 pounds over the delta. So was wondering if people could rate the delta on a scale between the CQR and Manson. Say with the CQR on zero and the manson on10 where would the delta go?
Looking around the 16kg/35lb range and seen the delta for £150ish and the Manson for £350ish.
I have had both a 16kg Delta and Manson Supreme for the last 5 years. At the time the price differential was much less. The Delta was a about £180 and the Manson about £250 - strange the way prices have gone!
I have used a Delta happily on the east coast and never had a problem with it setting or holding in the thick east coast mud. However, I have had a lot of trouble with Deltas failing to set or breaking out in hard sand. When it has broken out it has failed to reset.
The Manson has always set rapidly and held in both mud and sand. On a trip round the UK it only failed to set twice. Once in very heavy kelp and once in an area of shale/pebbles.
It can be a problem to get the Manson to sit well on some bow rollers and it can get clogged with mud between the blade and the roller in heavy mud. For that reason I often stick with the Delta on the east coast and put the Manson on when venturing anywhere near sand. This video is by Manson but does reflect my experience when using it. In the same situation I have watched the Delta skidding across the surface without setting.
